Author Topic: Equalizer and DSP Effects Windows Not Showing Up  (Read 501 times)
habibi
I recently just downloaded a Winamp DSP effect and used it but now I cannot see the equalizer or DSP effect windows. I only have one monitor and I've restarted Musicbee and my computer but the problem persists.
Go to Prefs/Player, then hit the "Equaliser & DSP" button in the lower right corner of the window.
habibi
Thanks for the alternative. Now I'm just wondering why I can't access them through the controls menu.
You can set up hotkeys for these and/or put them in the toolbar.
habibi
I put the DSP effects on a hotkey but it doesn't show up unless I go to the player preferences like sveakul suggested
I think you used the "Player: Toggle DSP on/off" selection.  To actually view the panel, you need to set a key for the choice "View: Toggle Show Equaliser."
habibi
This solved my problem! Thanks so much 😁
