Author Topic: Error when read directory  (Read 1100 times)
Fox63
When you enter your computer and try to read files directly from the directory.
computer
      disk C:
           Music folder
                File folder
MusicBee v3.5.8306.32075D  (Win10.0), 30 set 2022 10:56:
System.NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.
   in MusicBeePlugin.Plugin.panel_MouseMove(Object sender, MouseEventArgs e)
   in System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
   in #=zbJc9lwoXjhntRL0A7YT_sNc=.OnMouseMove(MouseEventArgs #=zXbqMvDk=)
   in System.Windows.Forms.Control.WmMouseMove(Message& m)
   in System.Windows.Forms.Control.WndProc(Message& m)
   in #=zpcLx4VImFjhJos7$w$NJBvQ=.WndProc(Message& #=z6t_jr_E=)
   in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
One of your plugins is causing the error. Disable all plugins via Preferences > Plugins and close MB. Launch MB and see if the issue reoccurs. If not, then re-enable one plugin at a time, checking to reproduce the issue and each plugin is enabled. Once the error occurs, you've found the plugin that's causing it. Then post the error message on the thread for that plugin so the developer can take a look at the issue.
If you're using the DLNA/UPNP plugin, I would disable -and- uninstall it before doing anything else as that has a history of issues - mostly severe memory use causing the PC to lock up.
Fox63
Thank you for your help. This is probably the case. In fact I had installed a plug in for testing, but I no longer remembered, almost certainly it was that. But I can't know immediately because closing and reopening musicbee the error disappeared without disabling any plug in.
In any case I have disabled all plugins except discogs and addition taggin tool which are the only ones that are useful for me.
Thanks again.
You're welcome.
I suggest uninstalling all the plugins that you aren't using any longer. You can always reinstall them again if you later decide they will be useful.
or just disabling them is sufficient
That depends on which ones. The DLNA/UPNP plugin has been known to cause massive memory leaks just by being installed and not used. I don't know of any others with this issue. Since the OP hasn't stated what other plugins they have, I suggested all of them be uninstalled.
