Author Topic: Space key bug?  (Read 378 times)
sneakout
Hello guys.
Every time Musicbee is running I can't insert the space character in text. The space key just pause/play the song and whatever I'm writing justlookslikethis, even if Musicbee is running in the background.
Any clues about how to fix this behaviour?
Thanks!
Musicbee v3.5.8150
Installed from website
Check your hotkeys configuration as you may have inadvertently set Playback: Play/Pause to your space bar.
sneakout
Ah! Ok!  :D
It wasn't inadvertently. I did set space bar as Play/Pause hotkey but I assigned it to Mutlimedia instead of Playback.
Thanks phred!  8)
You're welcome.
I love it when the solutions are so easy.
