Author Topic: ASCII Tools Plugin  (Read 920 times)
JonThysell
I've created a plugin which (for now) provides a $TransliterateToAscii() function which can transliterate (or "Romanize") Unicode text into ASCII. I use it to make sure that even if my tags are in Unicode, the files have names in ASCII, to prevent issues with other hardware/software that aren't Unicode-friendly.
For example given a track with the following Unicode metadata:
Artist: Israel Kamakawiwoʻole
Title: Lā ʻElima
and setting the naming template to:
$TransliterateToAscii(<Artist>) - $TransliterateToAscii(<Title>)
you would get the ASCII filename:
Israel Kamakawiwo`ole - La `Elima.flac
I wrote it because sometimes I use older devices that use FAT32 disks, and FAT32 doesn't always play nicely with Unicode in the filenames.
Source: https://github.com/jonthysell/MusicBeeAsciiTools
Download: https://github.com/jonthysell/MusicBeeAsciiTools/releases/latest
While my example shows a simple example of stripping the vowel accents (ā to a) and replacing the ʻokina with a backtick (ʻ to `), the underlying library, AnyAscii, can do far more impressive transliterations, like 深圳 to ShenZhen, or Δημήτρης Φωτόπουλος to Dimitris Fotopoylos.
Last Edit: September 27, 2022, 03:35:38 AM by JonThysell
