Author Topic: Enter key on keyboard instead of disk icon  (Read 1637 times)
Fox63
When you are adjusting some tags on many tracks you have to press on that little disk icon when you are done. It doesn't seem very comfortable to me.
Wouldn't it be better to hit the enter key on your keyboard when you are done entering?
If it is possible. Thank you
Edit > Edit Preferences > Hotkeys > Edit: Save
By default it uses Ctrl+S, which makes sense for a 'save' operation.
Testing it now, it appears there are some key combinations it won't let you use, including the Enter key on its own.
Fox63
It's true!!!. I hadn't thought of putting the enter key for the save as a shortcut.
It works but has a fairly serious shortcoming, if musicbee is open the enter key is intercepted in any application, even if minimized, so it does not function send anywhere. It is necessary to close the program.
However, I did some tests. Sending by itself is deleterious because it is intercepted wherever a sending is needed even in other programs.
I think the only solution is programmatically, when the cursor is an edit field it accepts the enter key as an save.
Or, even better, the data is saved when you leave the field.
All right!!! It was an idea but in the end it can be done without.
Last Edit: September 27, 2022, 07:20:59 AM by Fox63
