Author Topic: Saved settings bug.  (Read 491 times)
aktor
Often after a crash the app relaunch with messed  settings and loading the last saved settings often doesn't help. Always an issue with sidebar and bottom of main panel (wave bar) in music explorer. As a result I regularly  save settings and sometimes i have to go back months to correct the bug.
Often after a crash…
So what is the reason for all these crashes that you are experiencing?
It might be better to try and solve that first?
Exactly.
Your PC crashing is the issue, not MB. With a crash MB doesn't have time to save itself therefore it's in an unstable state upon restart.
If you think MB is the cause of the crash, check MB's error log.
aktor
The MB is crashing and not the PC.  The reason for the crashes is probably graphic visualizer's spectrum add-on, but I realy like it so i tolerate the crashes. I will post log after the next chrash .
Last Edit: September 25, 2022, 04:06:15 PM by aktor
