Author Topic: MusicBee resets Play Count (updates 3.5.8289 and 3.5.8296)  (Read 824 times)
Diaboliquin
I didn't notice it at first, but the 3.5.8289/.8296 updates resets the Play Count to 0 for several tracks. Video:
https://www.youtube.com/watch?v=3BLs9AvRuVQ
Version 3.4.8033 don't resets the play count.
I dont know what to make of this as its not been reported before and not something that has been changed. I guess you could send me a link to your settings file (help/ support/ view settings) so i can try myself
Diaboliquin
Yeah, really weird.
Settings: Check your pm.
Thank you for the prompt response.
I cant reproduce any issues with your settings file. However, make sure the tags tool plugin doesnt have any rules that would reset the playcount. But its more likely the problem is related to syncing the play count with last.fm. You could force a reset by renaming LastFmPlayCountCache.dat to another name so MB redownloads all the play counts from last.fm. Its located in the appdata folder (help/ support/ open appdata folder)
