Would it be possible to raise the contrast of the text in the status bar just a bit higher? I find the text in Dark just a tiny bit too dark, and the opposite in Light.
How to change the colours of a skin that you like.
Thank you! With a bit of color picking, it all went perfectly well!
A tiny bit strange for me was that while the status bar text was found in
element id="Panel.StatusBar.Default"
I could not only change the fg for the text, because then the bg went all black, so I needed to at least include bg:
<element id="Panel.StatusBar.Default" bg="47,53,61" fg="240,240,240" />
