Evening! I've been ripping some new-ish CDs today and am getting this error on the last 4 of 15 tracks on one of the CDs. Never come across it before. Clicking the "Re-encode" button doesn't fix it.
16/08/2022 17:53:33 - 10.0.22000.0 - 3.4.8033.18564D - System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
at System.Reflection.RuntimeModule.GetTypes()
at System.Reflection.Assembly.GetTypes()
at #=zMnhegC3cZoGqJc9MnQ==..ctor(#=zqTU3nglKnwb8VWp94Q== #=zTpbvKfM=)
19/08/2022 10:04:23 - 10.0.22000.0 - 3.4.8033.18564D - System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
23/08/2022 16:08:15 - 10.0.22000.0 - 3.5.8249.26390D - System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.Collections.Generic.List`1.get_Item(Int32 index)
at #=zniNq2ljuGSxgJkH$bUUHi23Ca$XV.#=zpFjD$b8ez9ML(Object #=zXBdTIBo=)
23/08/2022 16:25:09 - 10.0.22000.0 - 3.5.8249.26390D - System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
23/08/2022 16:42:50 - 10.0.22000.0 - 3.5.8249.26390D - System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
25/08/2022 19:19:41 - 10.0.22000.0 - 3.5.8249.26390D - System.IndexOutOfRangeException: Index was outside the bounds of the array.
at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
at #=zObqdaZsaRJXqcc75WA7AvB$8iFTA.#=zOKD_7mM=(Delegate #=zd5cVkNI=, Object[] #=zFR3NW8A=)
at #=zniNq2ljuGSxgJkH$bUUHi23Ca$XV.#=z$VKpUg1BMKQT35i0Tg==(Int32 #=zKveukIQ=)
at #=zGmsEjvmCCiXG9oFQigNkSlAI_HmW.#=zSe$klXy9rxkd.Invoke(Int32 #=zKveukIQ=)
at #=zGmsEjvmCCiXG9oFQigNkSlAI_HmW.#=z8TWrpUlQiLYlmW1fFg==(Int32 #=zL5EzIg8=, IList`1 #=zYfwKuwh3A6c8, #=zd1ObdBu9pkh23QftSw== #=zEnErPpr7W1M7)
at #=zGmsEjvmCCiXG9oFQigNkSlAI_HmW.#=zCukDp7Ex6Mod(Int32 #=zL5EzIg8=, Int32 #=zesKCS0M=, #=zd1ObdBu9pkh23QftSw== #=zEnErPpr7W1M7)
25/08/2022 19:19:42 - 10.0.22000.0 - 3.5.8249.26390D - System.IndexOutOfRangeException: Index was outside the bounds of the array.
25/08/2022 19:20:54 - 10.0.22000.0 - 3.5.8249.26390D - System.IndexOutOfRangeException: Index was outside the bounds of the array.
