Author Topic: How to allow for 'Progress Bar on Top / Bottom' on bitmap skins?  (Read 1918 times)
T010
I'm basing my bitmap skin on another bitmap skin which already had the progressbar in the middle. But (most) non-bitmap skins have the option to set the progress bar to either Top/Middle/Bottom where the Top/Bottom ones span the entire window width.
Now I can't seem to figure out which code I need to apply to my skin to allow for the Top/Bottom variants fo the progressbar. Tips please?
Side question: how to set the TrackPosition to not be split on either side of the progressbar, but rather combined on one end of it?
  • Heal The World
I don't think that's supported at the moment (for bitmap skins).
Do you have the source files of the skin which you are basing your skin off of? If not, I doubt this can be properly done either.
  • Heal The World
In the xml file, search for PlayerSplitProgressYOffset and comment it out (or even remove it if you want).
<!-- <element id="PlayerSplitProgressYOffset">0</element> -->
