Thank you for your prompt reply Frankz and Steven. My music is stored in two folders in Windows Music. One is titled Musicbee and I have a few tracks stored in a folder called 4Kyoutube to Mp3.
The artwork is embedded in each track.
When you look in those folders, are there any files in them besides music files?
The 3 digit numbers before each track are to keep the alphabetical order of the playlist when transferred to a USB stick otherwise the stick will jumble up the tracks randomly as it's Fat32.
You do not need to create a fake title tag to do this. If you tick "create a sub-folder for each playlist and its tracks," in the device sync settings (Edit->Edit Preferences->Devices...Settings...playlist storage), then this will be done automatically.
When you Google 'where does Musicbee store its artwork' you get that it will be saved to 'Folder.jpg' a Windows default, which has been removed from Win 11 as stated. Also as stated I do not have this folder.
Folder.jpg is not a folder. Folder.jpg is (generally) an album cover image file that would be linked to all files that sit in a specific folder. It is used when a user will have individual albums each in their own folder in lieu of embedding the artwork into each file. It is not a feature which would be added or removed from any specific version of Windows. People with Windows 11 can store Folder.jpg files just fine.
So clarification from you would be good as to specifically what settings I need in Edit-edit preferences-Tags 1 now you know how my music is stored. At the moment, under artwork storage, I have just the 'embed picture in the music file' ticked, and under 'set which pictures are displayed' I have just 'Embedded' displayed on its own.
This seems correct if there are indeed no separate image files in the two folders you say your music is in.
Can I simply delete all artwork from Musicbee and rescan? I have hundreds of tracks with hundreds of duplicate album cover artwork which I would like to delete.
If these hundreds of images are truly embedded in each of the files, I don't know of a way to do this in bulk. You would probably need to delete the incorrect images from each file. Someone will correct me if there's a way I'm not seeing.
With the above settings when I do as you suggested, select some music files from Musicbee Library, then right click-send to-file-rescan, nothing happens, all the scores of duplicate images remain with the tracks. Thanks
Yes, if they're all embedded rescanning will not help.
If you open one of these files in the tag editor (Right Click->Edit) and go to the artwork tab, it will show each image associated with the file. If you hover over each image with your mouse, it will tell you how that specific image is stored. I'd be curious if each image is actually embedded. Also, you can see there where you'll be able to delete each of the incorrect images (the Delete button).
A screenshot of this Artwork tab for one of the files might be useful for us to see.
If you open the playlist in MB and then go to Tools->Artwork->Album Artwork Manager, deselect all of the filters there at the upper-left and hit refresh, it will give you a list of all the files in the playlist along with the number of images associated with each one and how those images are stored. This will at least help you to identify the problem files that need to be corrected. A screenshot of one page of this might be useful, too.
