Author Topic: A loading message  (Read 3190 times)
ThY
Hello, are there any tips around to display a loading message ?
I'm asking that for a plugin i'm working on, which can take several seconds to do what is asked.
I would like the user to know something is going on.
I'm a beginner and i didn't find anything like that in the API methods.
Is the only way a window form opening and closing when the task is done ?
Thank you for your help :)
ThY
Thank you, i'm sorry for this useless post.
I swear i tried MB_SetBackgroundTaskMessage, but i don't know what i did, it wasn't working.
I just needed some sleep i guess. It's working fine :)
Is it good practice to remove the message with an empty string ?
yes, i always do this in my plugins.
