Author Topic: Getting radio-browser.info search to work in MusicBee  (Read 310 times)
feed1
Is there anything I can do to get the MusicBee Radio search function to work for https://www.radio-browser.info? Shoutcast and the other stations show results but https://www.radio-browser.info doesn't.
if you are using the store version of MB, just enter the genre into the search box in lower case.
Otherwise update to the latest patch version
