Author Topic: Clarity (X)  (Read 2443 times)
Clarity
I decided to revive my Clarity skin, which was released ten years ago, and started to rewrite it from scratch three years ago. It’s still a simple .xml file with some stuff I took from other skins I made for myself in the last few years, mainly from “Lost Child” which is another skin I used to release in 2018 and serves as the basis for Clarity’s remastered version.
The only things that resemble the original Clarity skin are the flat player at the bottom pane and the clean overall flair, but in the end it’s still Clarity. Great for anyone who likes smooth light interfaces. In addition, I included another version called “Clarity X”. It comes with the colour effect from the original skin’s flat player and has a more experimental approach.
DOWNLOAD LINKS
Internal Links:
Google Drive:
VERSION
SCREENSHOTS
NOTE
There might be odd oversights here and there, therefore please report if you notice something that hasn’t been addressed so far. Keep in mind that the X version is an experimental approach; some colour elements could interfere with each other in certain player setups.
I wouldn’t say the skins are accomplished in their current state, I’ve missed too many skin element changes in the last couple of years for that, but for now it should suffice. I recommend using the X version with the player in the bottom pane.
  • Lost Child will be re-released separately at some point in the future.
Last Edit: August 03, 2022, 11:42:27 AM by Clarity
ethereal12
How do you set ratings to percentages?
Clarity
These are manually entered custom tags. However, it is also possible to display the default rating system as Virtual Tags in numeric form.
If you specifically mean the display "/100": This is possible with the Virtual Tag formula: Pref>Tags 1>Define New Tags
Rating: {color: XX,XX,XX}<Custom Tag>/100
Then you can display the defined label as a field in other views as shown in the screenshot in the Artwork Layout.
You can find more about that here:
Last Edit: August 03, 2022, 10:46:33 AM by Clarity
