@Mayibongwe-
I unticked a couple of providers, updated, and saved but when I go back to the providers the just unticked providers have gone down to the bottom of the list - at the end of all the other unticked providers. Is there any way you can keep providers persistent? If I untick, update, and save and then go back, I'd like the provider to still be in the same order they were before I unticked them.
I got 15 our of 15 incorrect lyrics returned from 'fuzzy' providers so I disabled them and tried again. This time I got no lyrics returned. But when I went back to enable the just disabled fuzzy ones, they were at the bottom of the list and I had to move them back up to where I wanted them. I'm not concerned by the return of no lyrics since they were some very obscure songs. What -did- surprise me was that on the first run, I got lyrics for all the tracks. Which of course were all from fuzzy providers and were incorrect. I then had to go and delete the lyrics. So here's a case where I'd rather have the fuzzies disabled and get nothing. But then I have to reorder them once re-enabled.
Thanks.
