Author Topic: Manually rename a file within MusicBee via right-click context menu  (Read 230 times)
I realize file renames can be done via via the File Organiser panel after Edit/Rename, but it would be convenient to have the option to do so manually "Windows style" via a "Rename" choice in the context menu from the MB main window.
...via the File Organiser panel after Edit/Rename...
I'm not sure what you mean by this, but you can edit the Location field in the Edit panel to rename a file.
After you select Edit and hit the "Rename" tab, the File Organiser window appears with more advanced renaming options than some require:
My wish is just to offer a simple Windows-like rename option direct from the context menu.
Okay, but you would essentially end up with a duplicate of this field, albeit one that might be more "discoverable":
