Author Topic: Track number cut off if larger than 999  (Read 333 times)
jtcs
In my mixed track directories (aka self made compilation albums), I choose to use the track year as the track number, but it seems to be getting truncated - in this case "19.." - is there any way around this?
its a mistake for it to be using the ellipsis on track numbers. I will change that for the next update
jtcs
Latest beta does allow track numbers greater than 999, but spacing is off, overlapping last numeral and first character  - tried with several skins to make sure that wasn't the issue.  Image attached...
jtcs
Reverting back to the stable version as ellipsis are preferable to overlapping characters.  Hopefully this becomes resolved in the next version.
