the music files are NOT duplicated, just the listing within MB.
I'm not sure that's even possible, but it's easy to check.
Right-click both versions of a track and select Edit, and check their location on the Properties tab to make sure they're actually both referring to the same file.
Zak, that is it - one points to the physical drive and the other point to the network share:
E:\MusicBee\Ripped Files\Uriah Heep\Demons And Wizards\01 The Wizard.m4a
\\DESK01\MusicBee\Ripped Files\Uriah Heep\Demons And Wizards\01 The Wizard.m4a
Since I am wanting to network share this, how do I get rid on only the E:?
It might also be an embedded cuesheet. Right click on the files, and if it is the case then select 'Remove CueSheet'
Steven, I checked, no CueSheet
