Hi there, I've spent some time trying to get my phone and music library to play along, and have reached a sticking point.
When I sync my music to my phone, MB appears to successfully sync all four of my playlists. However, when I check my phone files, only the file for the first of my playlists alphabetically appears. This file is exactly in the location MB says it is saving the playlists, but the others do not appear. I have tried both m3u and m3u8 formats. Is there anything else I should try?
create a sub-folder and use relative file paths are both unchecked in my settings.
Thanks
