Author Topic: MusicBee File Paths: Installed vs Portable  (Read 10821 times)
karbock
MusicBee File Paths (Installed vs. Portable)
This summary is intended to help users wishing to:
  • switch from the installed to the portable version;
  • back up data;
  • transfer their MB setup to another computer.
Table of Contents
(1) Environment variables used
(2) Folders and files
(3) Adapting some settings after switching to the portable version
(4) Access and remarks
The table below uses several environment variables. Unless you have a particular Windows configuration or an older version, here are typical values:
Variable
Typical value (may differ)
%USERPROFILE%C:\Users\(YourUserID)
%APPDATA%C:\Users\(YourUserID)\AppData\Roaming
%LOCALAPPDATA%C:\Users\(YourUserID)\AppData\Local
%ProgramFiles(x86)%C:\Program Files (x86)
Their accurate values can be displayed from Windows' command-line prompt (cmd.exe). Examples of possible commands:
  • echo %USERPROFILE%
    will display the content of that particular variable.
  • echo %USERPROFILE%\Music\MusicBee
    will display the full path of that subfolder.
  • env
    will display all defined environment variables (a few dozens).
Nr.
Content
Files
Folder
(installed version)
Folder
(portable version)
AMain_settings
A.1Application settingsMusicBee3Settings.ini%APPDATA%\MusicBee\.\AppData
A.2Saved application settings*.ini%APPDATA%\MusicBee\Saved Settings\Application.\AppData\Saved Settings\Application
BLibrary_&_tagsInstalled versionPortable version
B.1LibraryMusicBeeLibrary*.*%USERPROFILE%\Music\MusicBee.\Library
B.2Library filters*.xautopf%APPDATA%\MusicBee\Filters.\AppData\Filters
B.3Custom tagsCustomTagConfig.xml%APPDATA%\MusicBee.\AppData
B.4Genre groupingGenreMapping.xml%APPDATA%\MusicBee.\AppData
B.5Tag hierarchy templates*.txt%APPDATA%\MusicBee\TagHierarchyTemplates.\AppData\TagHierarchyTemplates
CArtist_profilesInstalled versionPortable version
C.1Artist thumbs:
- Album Artist
- Artist
- Composer
- Original Artist
For Conductor/Lyricist, see D.1.
*.jpg%USERPROFILE%\Music\MusicBee\Artist Pictures\Thumb.\Library\Artist Pictures\Thumb
C.2Artist thumbs, resized from C.1*.png%LOCALAPPDATA%\MusicBee\InternalCache\ArtistThumbs.\AppData\InternalCache\ArtistThumbs
C.3Large pictures*.dat, *.tmp%LOCALAPPDATA%\MusicBee\InternalCache\ArtistBackdrops.\AppData\InternalCache\ArtistBackdrops
C.4Biographies*.bio.dat%LOCALAPPDATA%\MusicBee\InternalCache\ArtistData.\AppData\InternalCache\ArtistData
C.5Similar artists*.similar.dat%LOCALAPPDATA%\MusicBee\InternalCache\ArtistData.\AppData\InternalCache\ArtistData
C.6Soundtrack pictures%USERPROFILE%\Music\MusicBee\Soundtrack Pictures.\Soundtrack Pictures\
DIconsInstalled versionPortable version
D.1Genre / Genre grouping
Lyricist /  Conductor
Language / Mood / Occasion
Custom tags / Virtual tags
*.png%USERPROFILE%\Music\MusicBee\Artwork\Grouping Icons.\Library\Artwork\Grouping Icons
  • %ProgramFiles(x86)%\MusicBee\Icons
  • %APPDATA%\MusicBee\Icons
.\Icons
.\Icons
.\Icons
EPlaylistsInstalled versionPortable version
E.1Playlists*.mbp, *.xautopf%USERPROFILE%\Music\MusicBee\Playlists.\Library\Playlists
E.2Current playlistNowPlaying.mbp%USERPROFILE%\Music\MusicBee.\Library\
E.3Current auto DJ playlistAutoDj.xautopf%APPDATA%\MusicBee\Recent Queries.\AppData\Recent Queries
FSkins_&_layoutsInstalled versionPortable version
F.1Skins*.xml, *.xmlc
  • %ProgramFiles(x86)%\MusicBee\Skins
  • %APPDATA%\MusicBee\Skins
.\Skins
F.2Theater modes*.xml
  • %ProgramFiles(x86)%\MusicBee\Plugins\TheaterMode.List
  • %ProgramFiles(x86)%\MusicBee\Plugins\TheaterMode.Embeded
  • %APPDATA%\MusicBee\Plugins\TheaterMode.List
  • %APPDATA%\MusicBee\Plugins\TheaterMode.Embeded
.\Plugins\TheaterMode.List
.\Plugins\TheaterMode.Embeded
F.3Custom views*.mbv%APPDATA%\MusicBee\Saved Settings\Views.\AppData\Saved Settings\Views
F.4Custom panel arrangements (layouts)*.layout, *.tab-layout%APPDATA%\MusicBee\Saved Settings\Layouts.\AppData\Saved Settings\Layouts
GPlugins_&_equaliserInstalled versionPortable version
G.1Plugins(various)
.\Plugins
G.2Visualisers(various)
  • %ProgramFiles(x86)%\MusicBee\BBplugin
  • %APPDATA%\MusicBee\BBplugin
.\BBplugin
G.3Equaliser presets*.sde
  • %ProgramFiles(x86)%\MusicBee\Equaliser
  • %APPDATA%\MusicBee\Equaliser
.\Equaliser
HPodcastsInstalled versionPortable version
H.1IndexSubscriptions.dat%USERPROFILE%\Music\MusicBee\Podcasts.\Library\Podcasts\
H.2Episodes(audio files)%USERPROFILE%\Music\MusicBee\Podcasts.\Library\Podcasts\
H.3Artwork(picture files)%LOCALAPPDATA%\MusicBee\InternalCache\Subscriptions.\AppData\InternalCache\Subscriptions
IBookmarksInstalled versionPortable version
I.1Indexbookmarks.dat%APPDATA%\MusicBee.\AppData
When switching from the installed to the portable version, copying all your files to their new locations is the crucial part.
But not the last step: as MusicBee3Settings.ini and Subscriptions.dat still contain references to several folders, you need to perform some easy replacements in the files with your preferred text editor.
Caution:
  • Make a backup copy of MusicBee3Settings.ini and Subscriptions.dat before editing them!
  • When replacing an old path by the new matching one, ensure the new path exists in your portable version.
The variable parts depending on your particular configuration are in green below.
The drive letter (C: here) may also differ in your case.
(3a) In MusicBee3Settings.ini
Where in the file?Replace:By:
At the beginning:
<ENV_OrigSetPath>...
</ENV_OrigSetPath>
C:\Users\(YourUserID)\AppData\Roaming\MusicBee
or the value of:
%APPDATA%\MusicBee
(Portable MB path)\AppData
On the next line:
<ENV_LibPath>...
</ENV_LibPath>
C:\Users\(YourUserID)\Music\MusicBee
or the value of:
(Portable MB path)\Library
Below:
<ENV_KnownLib>...
</ENV_KnownLib>
or the value of:
all occurrencesC:\Users\(YourUserID)\Music\MusicBee\Playlists
or the value of:
(Portable MB path)\Library\Playlists
all occurrencesC:\Program Files (x86)\MusicBee
or the value of:
(Portable MB path)
(3b) In Subscriptions.dat
all occurrencesC:\Users\(YourUserID)\Music\MusicBee\Podcasts
or the value of:
(Portable MB path)\Library\Podcasts
Nr.
Content
Access
AMain_settings
A.1Application settingsPreferences
A.2Saved application settings(MB menu) -> Edit -> Saved settings
BLibrary_&_tags
B.1Library-
B.2Library filtersPreferences -> Library -> Music library -> define filters
B.3Custom tagsPreferences -> Tags (1) -> custom tags
B.4Genre groupingPreferences -> Tags (2) -> tag handling -> group genres
B.5Tag hierarchy templates(Tag Hierarchy Explorer menu) -> Edit Tag Hierarchy
CArtist_profiles
C.1Artist thumbs:
- Album Artist
- Artist
- Composer
- Original Artist
  • Music tab -> (Left panel) -> Album Artist / Artist / Composer / Original Artist
  • Music Explorer -> Artist Information -> Profile
C.2Artist thumbs, resized from C.1-
C.3Large picturesMusic Explorer -> Artist Information -> Profile
C.4BiographiesMusic Explorer -> Artist Information -> Profile
C.5Similar artistsMusic Explorer -> Artist Information -> Similar Artists -> More Similar Artists
  • Preferences -> Tags (1) -> artwork -> soundtrack picture locations
  • Learn the whereabouts on MusicBee Wiki
DIcons
D.1Genre icons / Genre grouping icons
  • Music tab -> Left panel -> Genre / Genre Category
  • Preferences -> Tags (2) -> tag handling -> group genres
D.2Highlighting iconsPreferences -> Tags (2) -> tag handling -> highlighting
D.3Toolbar iconsToolbar context menu -> Configure Toolbar…
D.4Tab iconsTab context menu -> Select Tab Icon...
EPlaylists
E.1PlaylistsPlaylists explorer tab
E.2Current playlistNow Playing tab
E.3Current auto DJ playlistAuto DJ tab
FSkins_&_layouts
F.1Skins(MB menu) -> View -> Skins
F.2Theater modes(MB menu) -> View -> Theater Mode
F.3Custom views(Main panel menu) -> Custom views
F.4Custom panel arrangements (layouts)(MB menu) -> View -> Import/Export
G.1PluginsPreferences -> Plugins
G.2Visualisers(MB menu) -> View -> Visualizer
G.3Equaliser presetsEqualiser button (player controls)
Last Edit: December 21, 2023, 04:43:14 PM by karbock
Awesome work
Mr. Trev
Fantastic bit of info
Considering the amout of questions regarding backup and new installs, I totally think this should be pinned somewhere…
I plan on doing that but I've asked the OP to make a few changes for legibility.
I'm not sure these are in the purview of your table, but in case that they are you may want to add them:
Custom tags - CustomTagConfig.xml - \AppData
Equalizer presets - .sde - \Equaliser
Library filters - .xautopf - \AppData\Filters
Genre grouping - GenreMapping.xml - \AppData
Program settings - MusicBee3Settings.ini - \AppData
Saved application settings - .ini - \AppData\Saved Settings\Application
Saved layouts - .tab-layout - \AppData\Saved Settings\Layouts
Saved views - .mbv - \AppData\Saved Settings\Views
Toolbar icons - .png - \Icons
Those are their locations in a portable install. I don't know where they are in the installed version.
karbock
Thanks! I've just updated the table.
Great.
Two nitpicking nitpicks:
- Skins are named Themes in your table. That's not wrong, but Skins is the term that is used pretty much everywhere, both in MB and on the forum.
- The table has .xmlc as a possible extension for Theater modes. I am pretty sure TMs are always .xml
karbock
Great.
I agree with you.
As for .XMLC as possible extension for TMs: I don't find any occurrence either.
karbock
Added entries:
* Artist profiles -> large pictures
* Artist profiles -> biographies
* Artist profiles -> similar artists
* Visualizers
Improvements:
* numbering
* access & remarks
Last Edit: October 04, 2022, 08:15:48 AM by karbock
karbock
Minor changes:
* %USERPROFILE%\AppData\Roaming -> %APPDATA%
* %USERPROFILE%\AppData\Local -> %LOCALAPPDATA%
karbock
Added:
D.4 - Tab icons (feature available from v3.5.8334)
karbock
Added:
* Adapting MusicBee3Settings.ini after switching to the portable version
* C.6 Soundtrack pictures
