Author Topic: Choose Folders not allowing subfolders?  (Read 435 times)
Azrenon
I had to move my folders and am trying to select a specific subfolder, but the choose folders section, especially of Monitored Folders, only allows me to see the base drives I have rather than the ability to get any deeper.
I just updated to MusicBeeSetup_3_4_Update2 to make sure it wasn't just a missed update, but the problem is still present. Help!
https://drive.google.com/file/d/1DrjiJe2GIg7f4htFQb6z4Yvnopu0PCSN/view?usp=sharing
Are you 100% certain that there are sub-directories under some of the directories in that screen shot?
And you got to that screen via Preferences > Library > monitored folders > choose folders?
I'm not seeing that behavior. All sub-directories are available via that dialog.
Just a guess ... What skin is that? Try a different skin. There should be a triangle to the left of each directory that has subs under it. Perhaps the skin wasn't created properly.
Azrenon
Thanks for taking the time to reply!
It seems like I had a very,  very old skin applied that aged out since the last time I messed with my MB Folders. Putting it to one of the included skins did indeed uncover the appropriate function.
Much appreciated, and SOLVED.
Great to hear it was that simple. And thanks for reporting back.
