I am very new to Musicbee but several weeks ago I started the task of rebuilding my library and playlists in Musicbee to get away from Itunes. Before I took the time to recreate 500 plus playlists I would sync and double check to make sure they worked, they did. I am syncing to a virtual device and then dragging the folders onto my phones SD card. When I do this, I am getting playlists where some are empty, and where some are missing more than half the files and a few where they have everything.
Now again because I am new I have searched for answers before posting here, and come up empty. I did try many of the fixes mentioned in case it was the same problem but to no avail. I have continued to build my library and playlists since I could still drag and drop them if need be. Any help would be greatly appreciated, as I really like the layout of Musicbee and I have learned it quite a bit.
Here is the info on my machines.
HP Envy laptop running Windows 10 Version 21H2.
Virtual Device is a folder on a Western Digital Easystore 12TB External HD
Phone is Samsung Galaxy Note 10 Plus 5g on Verizon Network running Android Version 12
