The OP (me) wants to maintain a master copy of MB on a desktop, and all new input, e.g. CDs, will be added on that system.
All music files are stored in Ripped Files, in the Library folder.
Periodically I want to copy the whole caboodle to a couple of laptops, using a SSD (for speed) as an intermediary.
My assumption had been that the Portable version would meet my needs, by using relative paths, and I changed from the standard version to portable. It doesn't seem to provide such facility, and I am testing out different options, taking note of the suggestions made, for which I am grateful.
From psychoadept:- "To supplement phred's comment, I believe the portable uses relative paths for its program files, but still uses absolute paths for the audio files, which could be anywhere on the system."
Yes, that may be true for some users, but it would be nice if there was an option where it was known (by the user) that all music was in one folder, e.g. Ripped Files, allowing relative addressing.
Thanks for the time spent and input.
PS I didn't reply to the early comment that using something like C:\MusicBee\........ wasn't allowed by Windows. I forgot to make the suggestion that it just seemed to be plain incorrect !
