Author Topic: Set toolbar buttons question  (Read 582 times)
stardepp
Which command do I need to select that matches Mediainfo.png? See screenshot:
And what other useful commands are there?
Last Edit: July 04, 2022, 02:28:55 PM by stardepp
  • Heal The World
Assuming "MediaInfo" is referring to an application on your computer, the command you'll have to use is the same as the one you've used for CD and tSpek.
If you are going to select Send To: External Application (selected files) [3], make sure the MediaInfo app is configured in the 3rd slot of Preferences > Tools.
Only the ones listed on that drop-down. If you are talking about external applications, I only know of the ones mentioned on this thread of yours.
The source code to any of my contributions is available on the same download link as the add-ons
stardepp
Thank you for the quick reply. What do I have to specify in Parameters, in MediaInfo?
"<URL>" works well.
Last Edit: July 04, 2022, 03:24:19 PM by stardepp
