I have found tag inspector but when I click on it, it is empty
But there is tags and the cue file is working very well (when I click on it using Windows explorer the songs are correctly displaying in Musicbee), when I click inside MB (album view)it is unable to display every songs, it displays only the FLAC file
You will say: file must have the same name as the file in the cue sheet, of course they are since otherwise they would not work, Foobar is displaying it very well
Any solution please?
