Author Topic: Resetting settings to default  (Read 2143 times)
AHAMAY
To be able to reset every setting and/or settings per page (yeah, like on foobar). Would make customization more comfortable, don't you think? Especially with panel arrangement...
Last Edit: June 26, 2022, 05:29:51 PM by AHAMAY
If you use the portable version, you can easily reset everything back to default simply by using a new portable version. Even while keeping the previous version. Just place the new portable in a different directory than the first.
AHAMAY
Decided MusicBee's a keeper. I realize I can just delete "%AppData%\Roaming\MusicBee\MusicBee3Settings.ini" but you know, convenience. Customizability seems to be one of MusicBee's strong suits (maybe even too customizable), this would make easier for the user to get a handle on each setting. Thank you for your interest.
