I just started trying to use MB. On the surface it looks simple and probably is, but I can't figure out how to get started. I have a folder with multiple sub folders where my music is located. I want to create a playlist for all the songs contained in those folders. This is why I'm feeling stupid, as I can't figure out how to do this simple task.
I am guessing I need to add the music to a library then somehow add that library to a playlist.
What are the steps I need to take to accomplish this?
Thanks, Rich
Note: The only way I can get my music into MB is by uninstalling then reinstalling and using the initial scan which allows me to point MB to the top level folder where the music is. then tell it to Scan. There has to be a way to do this later but I haven't figured out how yet.
