Problem is that in this case I'm using the subgroup "Disc number", without the preceding blank line. But MusicBee adds the blank line anyways, because it always adds it between discs.
Is that also the case when you are using the "compact grid" layout of the 'Album and Tracks' view?
For me, MusicBee
as expected does not add a blank line between the disc# subgroupings when I have the setting disabled
(but again, this is only true for the compact grid layout and not for the detailed list).
When using the detailed list, disabling the "precede with a blank line" setting works for other fields, but not for
Disc# and
DiscCount.
It's a default view, you can enable it like this:
Thanks Daniel. I had no idea there was such a layout in MusicBee. It looks great.
I played around with it and still couldn't find a way to change its artwork size or enable any grouping in there.
So unless somebody else does know of a way, I personally think you'll have to add this to the wishlist section.
