Author Topic: Tags not working well  (Read 1619 times)
danielcarrington
Hi, I started using MusicBee and I have this problem  :'(
These are .m4a files purchased from iTunes Store. They all contain the ITUNESADVISORY tag (with three possible values: 0, 1 or 2).
The rtng tag is what I'm trying to show in the custom tag ITUNESADVISORY:
But as you can see in the first screenshot it shows empty. Instead, the rtng tag is showing in the default Rating tag.
As you can see the files with a rtng value of 1 show a star and the songs with a rtng value of 0 show a bomb.
That's wrong, I think Musicbee is confusing RATE with RATING. How can I solve this?
mb does treat rtng as rating. Can you send me a link to a file with a value populated and also the iTunes.xml file
danielcarrington
@Steven I sent you a pm with the files.
I love this app, hope there is a way to make this work
  • MB Version: 3.6.8800 P
rtng in itunes is not the same as the star ratings in MB
rtng tag is content rating with 3 possible values:
0 = none
2 = clean
4 = explicit
itunes doesn't save star ratings to any tag, only to the database.
there are some apps that can save the star ratings to an unused/custom tag.
This version recognises rtng in the custom tag definition. You should use ITUNESADVISORY in the id3 tag field
danielcarrington
@Steve thanks! Now it recognizes the rtng tag:
But I can't modify it from MusicBee. I mean, I can, but it doesn't change neither in iTunes or Mp3tag. But if I change it directly in Mp3tag, it recognizes it correctly both in iTunes and MusicBee.
Last Edit: June 06, 2022, 06:08:57 PM by danielcarrington
0 = none
2 = clean
4 = explicit
Appears this info is now out-of-date.
From mp3tag mapping
ITUNESADVISORY
Content rating, use 0 = None, 1 = Explicit, 2 = Clean
and there is now a rate tag for star ratings
It seems there is a discrepancy with how this  tag is stored as compared to others. If you re-download the same link it should work with mp3tag
danielcarrington
@Steven Thank you very much!!! It works like a charm  :)  :)
This app is incredible
danielcarrington
@Steven Hey, I'm having the same issues with the COPYRIGHT (cprt) iTunes tag. Looks like MusicBee confuses it with the default COPYRIGHT tag, not recognizing it and/or overlapping it.
Also, the iTunes tags AKID, ATID, CNID, GEID, PLID, etc.. appear blank in MusicBee (Mp3Tag reads them correctly).
It would be great if MusicBee reads those tags too  8)
The Incredible Boom Boom
Just to let you know, this will more than likely need to be moved to a separate thread on the Wishlist board, or you can create your own topic.
Last Edit: August 10, 2022, 08:32:44 PM by psychoadept
danielcarrington
musicsnooper
Could you show how you achieved this ??
  • Heal The World
From left to right:
Left Sidebar-----------Navigator
Left Main Panel-----Thumbnail Browser
Main Panel------------Album Covers View > Customise Panel... > Show the tracks to the right of the main panel
Main Panel------------Album and Tracks View > Customise Panel... > Detailed List
Right Sidebar--------Playing Tracks + Track Information (stacked)
https://musicbee.fandom.com/wiki/The_Anatomy_of_MusicBee
Favourite song at the moment:   Decode by Paramore
