Author Topic: Dedicated Elements For These Arrows  (Read 2580 times)
  • Heal The World
arrows in the tag inspector
Currently, the default and disabled states of these arrows share the same colour element (Controls.Arrow.Default).
It would be great if the disabled state could get its own element (e.g Controls.Arrow.Disabled).
back/forward navigation arrows
Currently, the default and highlight states of these arrows share the same image element (PanelForward or PanelBack).
It would also be great if the highlight states had their own image elements.
The Incredible Boom Boom
+1111111111111
Yes, both these pairs of arrows are pretty confusing to manipulate
its already the case you can set an override image using "PanelBackDisabled" and "PanelForwardDisabled".
I will look to add "PanelBackHighlight" and "PanelForwardHighlight".
Last Edit: July 03, 2022, 09:31:30 AM by Steven
  • Heal The World
Thanks a lot for the new additions Steven.
As for the 'arrows in the tag inspector' case...
I am hoping the visualization below could be of some help in showcasing how things would look overall if we were to get a Controls.Arrow.Disabled element.
Last Edit: July 03, 2022, 11:37:59 AM by Mayibongwe
Controls.Arrow.Disabled is supported in the next update
  • Heal The World
Thanks again. Appreciate it.
  • Heal The World
Tried it out just now and the element is indeed taking effect just as intended. There's a slight issue I'm noticing though.
The downward arrow does not appear to be refreshing properly after clicking inside the tag box.
You have to hover over it before it can correctly switch to the default colour.
fixed for the next update
