Author Topic: Columns in search results  (Read 454 times)
MusicBebe
Is there any way to set things so that the columns in search results match the columns of the node being searched from?
Would be nice to save and load preset column settings. Playlists seem to be able to have their own column settings, which is related. But is there any way to apply one set of column settings to another node?
I still find myself adding and re-adding and resizing columns more than it seems should be necessary.
  • Heal The World
Can you elaborate (with screenshots too if possible)?
Favourite song at the moment:   Decode by Paramore
Not sure how well it relates to search results etc., but sorting presets can also be used as displayed columns.
I linked this in your playlist thread, too, but I think it also applies here. If you set a custom view and apply it to both the library and the search results, they should remain fairly consistent.
https://musicbee.fandom.com/wiki/Main_Panel_Views#Custom_Views
