Author Topic: [Skin Absolute Zero] Menu items are invisible without hovering  (Read 475 times)
bege
Hello,
I guess this is not intentional:
With the blue skin Absolute Zero the menu entries in the title bar (file, edit... help) are invisible without hovering over them. The respective entry in the xml file makes foreground equal to background of "MenuBar.Default".
I changed the entry from
	<element id="InlineMenuBar.Default" bg="0,100,0,0" fg="1,20,55" />
to
	<element id="InlineMenuBar.Default" bg="0,100,0,0" fg="210,210,210" />
You should post this on the thread of the skin in question so that the skin developer can address it.
