Author Topic: Default Hotkeys  (Read 963 times)
I've changed a number of hotkeys and enabled some that weren't enabled out of the box. This presents a problem when I'm explaining to someone which hotkey to use.
Is there a list somewhere which shows which hotkeys are enabled by default upon installation?
Thanks.
I haven't checked recently to make sure it's still accurate, but I know I put one on the wiki when I made that page.
Thanks psycho. It's up-to-date with version 3.0.5903, which was issued around May of 2016.
I have copied it into Notepad++ for future (offline) reference. It would be great if Steven could comment on any that have been added since that point.
Last Edit: May 21, 2022, 12:36:42 PM by phred
I realized I can install a second portable version and get the default hotkeys from there. No need for Steven to chime in.
Here is the list all all hotkeys that are enabled by default as of MB v3.4.8033. Thanks to psychoadept for pointing me to the Wiki.
Edit: Amend Clicked Column          F2
Edit: Configure MusicBee Preferences    Ctrl+O
Edit: Copy Tags and Artwork Only       Ctrl+C
Edit: Custom Search                Ctrl+F
Edit: Edit Tags                   Shift+Enter
Edit: Paste Copied Tags             Ctrl+V
Edit: Select All                   Ctrl+A
File: Remove (Delete)             Delete*
File: Remove (Hard Delete)          Shift+Delete*
File: Rescan/Add Files             Insert
General: Refresh                   F5
Multimedia: Next                MediaNextTrack (global)
Multimedia: Play/Pause             MediaPlayPause (global)
Multimedia: Previous                MediaPreviousTrack (global)
Multimedia: Stop                MediaStop (global)
Now Playing: Start/End Bookmark       Ctrl+D
Playback: Play Next Track          Ctrl+N
Playback: Play Now                Alt+Enter
Playback: Play/Pause             Ctrl+P
Playback: Previous Track             Ctrl+B
Playback: Queue Last             Ctrl+Enter
Playback: Queue Next             Ctrl+Shift+Enter
Playback: Stop                   Ctrl+S
Player: Volume Down             Ctrl+Alt+Down
Player: Volume Mute On/Off          Ctrl+Alt+V
Player: Volume Up                Ctrl+Alt+Up
Rating Now Playing: 0.5 stars Down   Ctrl+Alt+NumMinus
Rating Now Playing: 0.5 stars Up       Ctrl+Alt+NumPlus
Rating Now Playing: 0 stars         Ctrl+Alt+0
Rating Now Playing: 1 stars          Ctrl+Alt+1
Rating Now Playing: 2 stars          Ctrl+Alt+2
Rating Now Playing: 3 stars          Ctrl+Alt+3
Rating Now Playing: 4 stars          Ctrl+Alt+4
Rating Now Playing: 5 stars          Ctrl+Alt+5
Rating Now Playing: Unrated          Ctrl+Alt+-
Rating Selected Tracks: 0.5 stars Down    Alt+NumMinus
Rating Selected Tracks: 0.5 stars Up    Alt+NumPlus
Rating Selected Tracks: 0 stars       Alt+0
Rating Selected Tracks: 1 stars       Alt+1
Rating Selected Tracks: 2 stars       Alt+2
Rating Selected Tracks: 3 stars       Alt+3
Rating Selected Tracks: 4 stars       Alt+4
Rating Selected Tracks: 5 stars       Alt+5
Rating Selected Tracks: Unrated       Alt+-
Tabs: Close Tab                   Ctrl+W
Tabs: Create New Tab             Ctrl+T
Tools: Analyze Volume             Ctrl+Shift+V
Tools: Auto-Organize Files          Ctrl+R
Tools: Auto-Tag by Album          Ctrl+Shift+T
Tools: Auto-Tag by Track - Update Tags    Ctrl+L
Tools: Rip CD                   Alt+R
View: Show Now Playing Assistant    Alt+J (global)
View: Show Now Playing Track Finder    Alt+F
View: Show Tag Manager             Alt+E
View: Show Visualizer Full Screen       F11
*- Delete and Shift+Delete are assigned as hotkeys but they cannot be reassigned. Delete acts like the Delete menu command (Remove, in playlists). Shift+Delete will remove selected tracks from playlists and the library and send the files to the Recycle Bin. Whether you get a warning for this will depend on your Confirmation Settings.
Last Edit: May 21, 2022, 03:37:06 PM by phred
