The navigator panel is not only on by default (and can't be disabled,) it will always appear in the left sidebar. Note that the check (tick) mark for it in the panel arrangement config is grayed-out.
Thanks, Zak, I was able to make that other menu on the left hand side show up for a moment, for a moment so I could access the Auto DJ panel. Damned if I can do it again, though.
