I can't be sure about your setup, so just two assumptions here:
- The bulk of your library is tagged properly and you are satisfied with how everything is functioning and displaying in general.
- You have some folders that contain tracks that are still 'raw' and have not yet been tagged properly.
If that is the case, what would you like to have that tab displaying exactly?
Sorry, maybe I probably didn't have a good articulation of the meaning.
Suppose, I currently have 5000 songs, which are located in five folders according to different song styles, such as classical, rock, pop, movie soundtrack, and world. The music library displayed in the current main interface will display all the songs in alphabetical order, which is very good, and I am very satisfied.
But I had some whims yesterday. I hope to be more customized. For example, I want to customize the display of the tabs in the picture below. Each tab displays the songs in the folder. In fact, these few Tabs are still using a unified music library.
Maybe it's possible to customize the displayed tabs?
