I've been reading here and there and it looks like MB can sync its play counts (and ratings) to Poweramp and vice versa. I use the Music Bee Wifi Sync app and it works well for syncing my files and playlists, but I can't sync play counts. I'm using Musicbee 3.4.8033 and my phone is Android 11. I discovered the two way sync earlier and thought that must be it. However, it's grayed out in the versions past 3.3.6904. I tried the previous version, but it simply does not recognize my device when connected via a wired connection. I also tried other versions with two-way sync but I always get the error (COPY FAILED - THE REQUESTED VALUE CANNOT BE DETERMINED) so I just gave up on those versions and returned to 3.4.
Anyway, can MB still sync play counts to Poweramp? Am I missing something? I just want them to be the same since I mostly look for songs to play through my most played section. Thought about simply syncing my play counts from last.fm to Poweramp but I don't think Poweramp can do such thing.
