Author Topic: Add a way to locate missing files in manual playlists  (Read 94 times)
Versiris
Having to manually re-populate a playlist with songs after I change a folder name or file name is a huge pain. Please add a way to locate missing files, something like what After Effects does, for example, where it opens a window for you to select a folder and then it will automatically find the files.
