Right now when you choose artwork for a track/album it does not give you the option to "link to the original picture file". This means in order to select this, you need to add some art you don't want, exit that dialog box, add the art you
do want, only
then does ""link to the original picture file" show up.
Here is what it looks like when you first add an image.
Here is what it looks like after you exit and add
another image. It should let you do this
the first time. This should be the default option.
