Author Topic: My Various Tagging Questions  (Read 775 times)
Dalinar
1) is it ok to tag a file while it is being played? e.g. I select an album and tag the whole album, while of its songs are playing?
2) what would be the easiest way to apply a tag (e.g. a keywords tag) ? without having to type it in every time? I tried the quick tags plugin but that plugin won't run on my computer for some reason.
Yes. Tags and lyrics edited/added while a song is playing won't get saved to the track file until the song is stopped. Not paused. Stopped.
I'm not familiar with the "quick tags" plugin and don't see it listed in the plugins section of the forum. Where did you get it?
You can select all the tracks that are going to have the same keyword(s) and open the Tag Editor and add the keyword(s). It will get save to all the selected tracks.
Check out the MusicBee Wiki.
Dalinar
Dalinar
to be honest what I do is add the tag "new" to the keywords tag. I know, sounds stupid as you can just make a playlist that sorts by the date added. However, I do this because then I can un-new it later after I've listened to it.
Ideally this Additional Tagging plugin (forget the exact name) would be best, as it can add tags automatically but as far as I understand it - it cannot just add the tag to the files in the inbox but will add the tag to any file that has been modified, which I'm sure there is a good use for this but it escapes me why anyone would want to add a tag every time any mp3 file is modified.
Dalinar
What happens if the track is still playing when MusicBee is exited? I noticed that when MusicBee is opened the track will resume playing. At what point does the tag get written?
1) upon exit even though the file was playing ?
2) upon restart of MusicBee after the song is stopped?
3) some other time?
Dalinar
https://getmusicbee.com/forum/index.php?topic=35032.0
how do you magically ungrey (enable) the boxes there? like the one that lets you select "genre" ? or the ones below it?
Click on it. (with your mouse)
Dalinar
I don't really understand what to do, clicking doesn't enable the boxes
https://imgur.com/uSpBo4y
sorry about the link but i couldn't figure out how to use the img tags
That doesn't look like the preset I directed you to?
Dalinar
ah I couldn't download it because bitly says it is harmful and there was no way around it - the preset link is a bit ly link
3) some other time?
If you close MusicBee with updates pending,  I would expect the tags to be updated at that point, between when playback stops and the process is ended. Steven would have to confirm, though.
You could also make an auto-playlist that shows tracks with a Play Count of zero (and maybe use Date Added to also restrict it to newly added tracks).
3) some other time?
if you exit MusicBee normally or its a normal windows shutdown while MB is still running, the file is saved before MB closes
if its a forced windows shutdown then the file is not saved.
