I want to permanently set the MusicBee player to switch to Theatre Mode on playback, but it only works occasionally. Most of the time when I begin to play something it won’t switch to Theatre Mode.
It will switch the first time I begin to play an album after opening the application. If I then stop playing that album and choose a different one, or the same one again, it won’t switch to Theatre Mode on playback.
If I close and re-open MusicBee and select something to play, again it will switch to Theatre Mode successfully. But if then select a different album and play it, it doesn’t then switch to Theatre Mode.
So if I want to change the music I’m playing and want to have the player switch to Theatre Mode on playback, I have to close MusicBee, re-open it and then play the album I want to play.
This is the case no matter which of the included Theatre Mode views I select. It also occurs if I use a downloaded Theatre Mode style.
The problem only seems to apply to Theatre Mode. If I set the application to switch to the Compact Player or Mini Player on playback, it works fine.
I am using MusicBee Portable and have version 3.4.8033 P
Any idea what could be causing this problem? Or is this how it’s meant to behave?
