Author Topic: Problem switching to Theatre Mode on playback  (Read 1448 times)
Paulie Paul
Thanks to you (and Mayibongwe) for providing a fix for my initial TM problem.
On the patch file you sent me, I just thought I should let you know I've had a problem running it.  I get a start up error message saying it's thrown an exception.
In case it's something you want to look into, I've uploaded to MediaFire a text file with full details of the error and screenshot of the error message received.
Here are the links:
https://www.mediafire.com/view/qngxk80zi7fmhin/Capture_-_MusicBee__Patched_-_Start_Up_Error_Message_-_from_Paulie_Paul_30.04.22.JPG/file
https://www.mediafire.com/file/jw2e7flrzksbsxg/ErrorLog.dat_-_from_Paulie_Paul_30.04.22.txt/file
I daresay the info given in the files will mean a lot more to you than it does to me.
Are you certain that you followed Steven's directions?
You do -not- run the exe that's in the patch. You take the files in the ZIP and move them to the directory where MB is installed. And let them overwrite the existing files.
  • Heal The World
Working flawlessly now. Thanks.
Favourite song at the moment:   Decode by Paramore
