Author Topic: steven_mayall folder?  (Read 585 times)
Mr. Trev
Looking round my computer and I noticed I have a "Steven_Mayall" folder in my appdata/local folder. Inside are a couple other folders, which contain a user.config file each. What's the purpose of these and do I need to keep them (the last modified dates are from 1+ months ago)
Are you using, or have you ever used, the Store version of MB?
Mr. Trev
HAHAHAHAHAHAHAHAHAHA
no.
Only been using portable installs for ages now. Thinking back, I might have gotten a debug from Steven to try and solve some issues, but I can't be positive about it
Yeah, I know, but I felt I had to ask the obvious. Most long-term users wouldn't be using the Store version. I guess you'll have to wait for Steven to reply.
Its not created by MusicBee. Perhaps some installer software or other tool being used
Mr. Trev
It's possible one of my external tools created it, but my most often send to> is Picard and I've been using it for long enough to assume it's not that.
I guess I'll go ahead and delete the folders… WCGW? :D
