Author Topic: MusicBee Beta 3.5.8146 ignore media keys.  (Read 1108 times)
Diaboliquin
After updating to the latest beta (3.5) the multimedia key play/pause stop working (other user reports the same bug). MusicBee detects correctly the key when pressed in the Hotkeys section, even I can rebinded the key, I tried with Playback: play/pause, but the key only works one time after re-opening MB.
I checked with other players, the key works.
Last Edit: April 24, 2022, 05:55:42 PM by Diaboliquin
edit:
do you have the media control plugin installed and enabled?
Last Edit: April 24, 2022, 11:31:18 PM by Steven
Diaboliquin
edit:
Yes, after deactivating the plugin the keys work. Thanks for your support.
I have reverted back to the v3.4 behaviour. The link in the v3.5 beta topic has been updated
