Author Topic: Rate Sync MusicBee -> Android dont work  (Read 632 times)
MrVain712
Hey,
i use MusicBee 3.4.8033 (Windows 10) and Poweramp with MusicBee Wifi Sync on my Oppo Find X 3 Pro (Android 12) I have the problem that the Rate Sync MusicBee -> Android dont work. Android -> MusicBee works fine...
What i must do? MusicBee saves the ratings in the Mp3 tags, i have check this... But dont send it to my Android :(
MrVain712
probably your android player is not reading the ratings file tags
MrVain712
is this possible with poweramp? Or is Gonemad better to use?
You should take this question to PowerAmp folks. Perhaps they have a user forum. Or a way to contact the developer.
