Author Topic: Tagging Tools - ability to search for lyrics under 100 characters  (Read 651 times)
belomeclone
Right now in MusicBee the Tagging Tool is a powerful way to help keep your library organized. When it comes to lyrics, if you are saving your lyrics to the file it can show you which songs do not have saved lyrics. What I am requesting is the ability for it to tell you when the lyrics are too short. I figure 100 characters is plenty, though if people save their files with the "Instrumental" tag maybe less would be better, or maybe the option to filter out certain words.
Either way, I come across some tracks where there is data in the Lyrics section that is not lyrics. This would help you sort that and further keep things clean and organized.
Thank you!
Make a new virtual tag called "Short Lyrics" or something similar.
$IsNull(<Lyrics>,False,$If($Len(<Lyrics>)<100,True,False))
Then you can just do a search for tracks where Short Lyrics is True.
Or use it to populate a Filter, or show it in a column or whatever else you find easiest to work with.
belomeclone
That was very helpful, thank you!
I am still discovering how powerful MusicBee is!
