https://getmusicbee.com/patches/MusicBee35_Patched.zipunzip and replace the existing musicbee application filesnote that its been updated to now use .NET 4.8if you have any issues please let me know
... the encoder seems to be getting cut off due to being too long.
Quote from: SonicRings on April 10, 2022, 07:13:12 PM... the encoder seems to be getting cut off due to being too long.Does the full path appear if you hover the cursor over it?
