@musicbee4jojo- if you're using the Store version of MB you can not use the patch vincent kars suggested. Nor can you use -any- patch. If you are indeed using the Store version, I suggest you download and use the Portable version. You can get it from the first forum topic or from the website's download page. Place it in a non-UAC directory such as C:\MusicBee. Once "installed" then apply the latest 3.5 patch from my signature or vincent's link.
