Author Topic: How to stop star ratings of selected tracks disappear when you click away?  (Read 140 times)
RawkLee
When you select a track, and then click away, it makes the star rating disappear. Is there a way to stop this / turn it off?
It's only fine when you click on the same panel.
Does that happen with MusicBee's default skin too?
What version of MB are you on?
(it seems it could be an older version?)
RawkLee
It's a custom skin, and i messed something up. I got it working, my bad. Should I delete the post?
