Author Topic: Where to find album sorting/grouping in settings file?  (Read 373 times)
jangjang
So I was messing around with the fields that define albums and put date added as one of the fields. This caused Musicbee to crash and it no longer launches at all. Just crashes right away I assume.
Since I don't want to make a new library/redo all my settings, I was wondering if I could find the location of these fields in the files and edit them manually? I checked the file in appdata, the config in the main folder, and the library settings file but couldn't find anything. Would really appreciate any help with this. And I'll try not to be this stupid again lol
can you send a link to your settings file so i can see and fix the issue?
there isnt a single easy way to find all the different relevant settings
jangjang
Here is the link: link
This is the settings file from the appdata/roaming/musicbee folder
Thank you so much for the help!
The issue is: <TagAlbumGroupingField1>180</TagAlbumGroupingField1>
i dont think it will be possible to include an attribute like AlbumDateAdded as part of the definition of an album
jangjang
Ah ok. Yeah I don't know what I was expecting, I was just messing around with it haha. Thanks so much for the help!
