Author Topic: How to mark track as played? Couldn't found solution  (Read 607 times)
musicbee4jojo
Hi!
How can i set track as played?
There is nowhere any item in the menu to set it.
Thanks,
I use muscbee version 3.4.7805.
vincent kars
There is tag called "play count"
Normally we don't edit it because it is updated automatically.
However, select a track > Edit > Properties and you can manually edit the Play Count
musicbee4jojo
Thank you!
I got the context menu!
But if i click it, it happens nothing.
Any idea?
Maybe is this a problem by skin?
BTW: How to upload a screenshot as a file? I have not an URL for that.
Last Edit: March 31, 2022, 12:19:32 PM by musicbee4jojo
musicbee4jojo
I've reinstalled musicbee once more again.
I always see the same behavior.
Right click on the track, choose "Edit" and nothing happens.
No new windows etc..
What did i do wrong?
musicbee4jojo
Any idea?
Or is this not possible, because the last.fm rules prevent it?
Changing to "play count +1: more than 25% of track played or 60 seconds" is not possible too.
Prevent by the last.fm rules?
It is my files!
How about my rules for my own files?
How to set it played or not?
vincent kars
musicbee4jojo
Thanks!
Which musicbee version do you use?
I can't got the same popup windows.
Mark the track and click the right Mousebutton and click the "Edit" from the context menu.
Nothing happens.
@musicbee4jojo- if you're using the Store version of MB you can not use the patch vincent kars suggested. Nor can you use -any- patch. If you are indeed using the Store version, I suggest you download and use the Portable version. You can get it from the first forum topic or from the website's download page. Place it in a non-UAC directory such as C:\MusicBee. Once "installed" then apply the latest 3.5 patch from my signature or vincent's link.
musicbee4jojo
@phred and @vinvent kars
Thank you a lot.
I've noticed it.
In the meantime, i got another solution to mark track as played.
I've installed Addon "QuickTag" and use this tag to set the tag played with the value 1.
With shortcut like Alt+a (played = abgespielt in german).
